Stock Muffler Delete
Old Jun 23, 2009 | 12:55 AM
HIF350's Avatar
HIF350
I have a 1999 f-350 7.3 diesel Dually. I want to do a stock muffler delete. I have read many of the threads on this subject. First of all , I understand you need a 3.5 straight pipe for the stock exhaust. How long should the pipe be cut to? Second, I assume the straight pipe purchased will be 3.5 OD or 3.5 ID? Third, the stock exhaust is 3.5 ID or 3.5 OD? I want the ends to slip over and clamp to the stock exhaust. So what size should the flared ends be 3.5 ID?? Is this correct???
Old Jun 23, 2009 | 01:15 AM
4inchlovin's Avatar
4inchlovin
Welcome!
I'd buy this and clamp the **** out of it....
MBRP Universal Muffler Delete Pipe
Old Jun 23, 2009 | 01:29 AM
PaysonPSD's Avatar
PaysonPSD
First you can determine if the stock exhaust is 3 1/2" ID or OD by measuring it at the end of the tail pipe. It is the same OD pre and post muffler.
The length of the delete pipe will be determined by two things. 1. The lenght of the muffler and pipe you cut out. 2. The length of the flares on each end of the delete pipe. The length of the flared ends must be added to the length cut out. The ID of the flared ends should be the same as the OD of the stock exhaust that you measured.
If you can find the proper ID tube you will not have to have it flared at either end. If this is the case allow about 3" overlap at each end and add 6" to the length that was cut out.
Also you should consider the hanger at the rear of the muffler. With the muffler removed you have to add a new hanger so it matches up with the stock hanger mount.
Edit: Nice link Nolan. I wonder if they supply the pipe with a hanger.
Edit 2: MBRP delete pipes come in only 4 and 5" size. Is that why you would clamp the chit out of it?
Old Jun 23, 2009 | 01:44 AM
HIF350's Avatar
HIF350
The answer I am looking for is based on a stock exhaust pipes . So if the stock pipes at are 3.5 OD then the Straight pipe should be 3.5 ID. Are the straight pipes normally sold 3.5 ID? So with this being said then the exhaust on a 1999 f-350 are usually 3.5 OD? The reason I am asking is the truck is located 200 miles away and I have no way of getting to it to measure it.
Old Jun 23, 2009 | 01:57 AM
PaysonPSD's Avatar
PaysonPSD
I just measured the stock exhaust I cut out and it is 3 1/2" OD. Forgot I had it laying around. I only had to walk about 100' round trip.
Old Jun 23, 2009 | 09:56 AM
4inchlovin's Avatar
4inchlovin
Believe it or not i have a muffler on my truck. That is why it sounds different then other trucks that are straight piped. If you get 4" delet pipe with the flared ends it should clamp down just fine on your stock 3.5" exhaust. And for $37 it seems like a good deal.
Old Jun 23, 2009 | 11:00 AM
HIF350's Avatar
HIF350
Thanks for the info
Old Jun 23, 2009 | 11:06 AM
wla6518's Avatar
wla6518
This is the one I put in:
http://www.puredieselpower.com/catal...ipe-p-635.html
it is a bit more than the other, however, there was piece of mind that it would fit when it arrived. Total time under the truck was about 10 minutes.
Last edited by wla6518; Jun 23, 2009 at 11:08 AM. Reason: posted the wrong link origionally
Old Jun 23, 2009 | 11:28 AM
Mike F250's Avatar
Mike F250
where are you located? I will be installing a 4 inch system soon. I have the straight pipe welded onto mine. Easy enough to give it away. Not so easy to ship it.
When I did mine I had an old exhaust system from a friends truck. I cut a straight section from his old system and turned the pipe in front of the muffler over. A straight section fits right in then.
Old Jun 23, 2009 | 12:04 PM
HIF350's Avatar
HIF350
I will take the pipe and pay the shipping to Hawaii 96789
Old Jun 23, 2009 | 12:12 PM
RobertJohn's Avatar
RobertJohn
Dang, that first link sould be just what i'm looking for.
Being straight and all I could use it for a cat delete pipe.
Has anyone tried or used it for that ?
Old Jun 24, 2009 | 10:16 AM
RobertJohn's Avatar
RobertJohn
I'm bumping this because I'm curious about using the muffer delete pipe as a cat delete.. It seems to me if I just measure correct, cut the it should clamp right on..
Any help or suggestions ??
Old Jun 24, 2009 | 10:46 AM
PaysonPSD's Avatar
PaysonPSD
That will work just fine. Same as a muff delete. Hang onto the CAT just in case, you never know.
Old Jun 24, 2009 | 11:01 AM
danskool's Avatar
danskool
Go Bills !
Same here..
grcutter
May 30, 2017 10:39 AM
Jrob76
May 24, 2017 06:24 AM
S10SAS
May 18, 2017 01:13 PM
fordboy97
1997 - 2003 F150
Feb 12, 2016 01:10 AM
live2hunt
Exhaust Systems
Sep 1, 2007 05:17 PM
