Dash Brake light...
Old Jun 22, 2009 | 04:05 AM
El_Jefe's Avatar
El_Jefe
Exclamation Dash Brake light...
As I drove home this evening it would blink intermittently. Brakes did not seem any less responsive than "normal"....
Any ideas what would trigger it??
Old Jun 22, 2009 | 07:51 AM
Monsta's Avatar
Monsta
Sit. Stay.
Check the fluid level in your master cylinder.
Is your parking brake pedal all the way up?
Old Jun 22, 2009 | 11:28 AM
El_Jefe's Avatar
El_Jefe
Yeah I checked that multiple times. I will go check the fluid level this morning...Thanks
Old Jun 23, 2009 | 04:47 AM
lowdownndirty's Avatar
lowdownndirty
and if neither of those fix it, check the rabs unit, it might be going out or a bad contection to it.
also on your E brake assembly, check the wire going to it, maybe a bad conection there too.
Old Jun 23, 2009 | 11:24 AM
El_Jefe's Avatar
El_Jefe
I topped of the fluid and no more light...whats a rabs unit?
Old Jun 23, 2009 | 01:03 PM
bigrigfixer's Avatar
bigrigfixer
The Pacifier
rear abs.
Your truck probably doesn't have one.
Old Jun 23, 2009 | 02:47 PM
El_Jefe's Avatar
El_Jefe
As I was driving into town I realized the acronym...my truck does have a plug for it hanging above the rear end but the rear end that was installed does not have the plug in for it...
Old Jun 24, 2009 | 12:14 PM
lowdownndirty
possible, your truck did not have one, but Im betting it did.
look under your left side frame rail on the inside, about a 1ft behind the exuast maifold out let, and see if you got a little box thing like this that your brake lines run in to.
thats the rabs unit aka the brake nanny
Old Jun 24, 2009 | 01:57 PM
El_Jefe's Avatar
El_Jefe
okay I will check it out. I pulled the drums off yesterday and found that there where a leaking wheel cylinder and no shoes on the left and the right side was hanging up.
51PanelMan
Ford Truck Parts for Sale
Dec 15, 2013 09:23 PM
gregstith
35
Jul 31, 2013 06:39 PM
djed
Sep 20, 2012 01:26 AM
66fdtrucknut
Maryland Chapter
Aug 26, 2010 07:47 PM
sbfishman
23
Jan 12, 2010 11:47 PM
