transmission
Old Dec 28, 2001 | 05:06 AM
Darryl's Avatar
Darryl
transmission
I have a 97 f350 PS,manual trans with 143k.I can feel a viberation coming from trans.Was told it was input shaft bearing.Anybody had to replace one?Wondering how dificult it is to replace.Any input on the this would be great. thanks Darryl
Old Dec 28, 2001 | 02:53 PM
lanero's Avatar
lanero
transmission
Yes. I replaced one in a Mazda TOD in an '84 F150. It wasn't too bad. Hardest part was getting the trans out. I didn't need one, but some trans require the input bearing need a puller (to remove old) and a press to install the new one.
Roger Lane
Old Jan 2, 2002 | 12:08 PM
busdriver1's Avatar
busdriver1
transmission
It may also be that your Dual Mass Flywheel is going bad. If it the Dual Mass Flywheel it will probably be pretty easy, but expensive (parts costs) to fix. If it is the input bearing I would think it might be quite a job as the ZF 5spd (the transmission you have) is quite an interesting animal with lots of special tools and procedures for repair.
Old Jan 2, 2002 | 10:29 PM
redneckdieselmechanic's Avatar
transmission
darryl_t
New Member Introductions
Feb 14, 2014 06:27 AM
1978fordtruckgirl
Oklahoma Chapter
22
Feb 22, 2005 08:25 AM
dazman
1978 - 1996 Big Bronco
Jun 8, 2004 11:30 PM
Darryl
Aug 12, 2003 09:39 PM
Darryl
Mar 12, 2000 09:26 PM
