Aerostar Ford Aerostar
tranny blues
Old Jun 21, 2009 | 10:07 PM
little d's Avatar
little d
tranny blues
new to this computer forum thing. my headache is i have 95 astar 4liter a4ld. trans went so i bought 87 astar 3liter a4ld fresh rebuilt. changed bellhousing for my 4liter and added 3-4 servo to valve body. now know i have to reuse old valve body plate. problems: doesnot go into reverse easily (i usually wiggle selector lever for reverse to engage) does not want to come out of low gear when cold (once 2nd is reached it works fine) has new modulator. finally converter does not lock up. tranny worked fine in 87 doner van. i need some help WHILE I STILL HAVE HAIR. thanks to any help!
Old Jun 21, 2009 | 11:00 PM
Bear River's Avatar
Bear River
Former ******
Doesn't a '95 use a 4R44e transmission? I thought '94 was the last year of the A4LD.
The valve bodies are tempermental and unless this seal perfectly, you get cross leaking which causes lots of behavior problems. Why not rebuild the old trans, that typically gives better results than swapping in a trans from an older year.
Old Jun 22, 2009 | 02:28 AM
Pablo-UA's Avatar
Pablo-UA
this way tranny will not work. First of all ajust controll cabel.
Valve bodies are different and old A4LD actuate OD w/o computer. You need one solenod only - for Lock Up.
Are you sure you had A4LD, not 4R44E?????
