newbie grille ?
Old Jun 21, 2009 | 05:22 PM
jlang's Avatar
jlang
newbie grille ?
is the grille connnected to the part behind it that holds the head lights or are they two diff. peices if separate how can i remove without damaging the grille
sorry for yet another dumb question
john
Old Jun 21, 2009 | 08:19 PM
sdetweil's Avatar
sdetweil
john
yes, there are 3 bolts thru the air dam into the headlight buckets. You get to them from inside the fender. There is also the vertical upright in the center that is bolted to the front gravel pan and the valence. (and the grill itself)..
so a total of 8 bolts to get it out, and then 1 to separate the support from the grill.
wiring separation extra!..
Sam
