Bushings
Old Jun 21, 2009 | 03:29 PM
calf roper's Avatar
calf roper
Bushings
There is a bar behind my front axle that I guess you would call a stabilizer or sway bar.The bushings where it connects to the bar from the frame look pretty bad.Rubber is starting to come loose from around them.Anyone replaced these and what is the proper name for them?Thanks
Old Jun 21, 2009 | 04:01 PM
new2diesel's Avatar
new2diesel
Yup, stabilizer bar/ sway bar bushings. I replaced the ones on the axle with Moogs.
Did both fronts and rears, don't know which part #'s are which
K80072
K80201
Also the links themselves either McQuay links bolt ons or some on here press out old
and put in poly bushings from Energy suspension products. It was faster for me to bolt on replacements. I had a friend press out the old ones so in the future if needed I can
get them from Energy.
