Driveshaft removal!!!
Old Jun 21, 2009 | 02:07 PM
Ole'Blu's Avatar
Ole'Blu
Question Driveshaft removal!!!
I wrote in yesterday about towing my 1995 F150 2WD, and I had a few great responses on how to do that the easiest way. One of those being that it would be best just to remove the driveshaft. So I pulled out my haynes manual, and instructions on the removal are very vague. I am by no means a master mechanic, and I just want to make sure that I don't do any major damage to my beloved truck. If there's anyone who has the time to help me with this one, I would greatly appreciate it.
Ole' Blu
Old Jun 21, 2009 | 02:10 PM
17fordguy's Avatar
17fordguy
pull the 4 bolts that hold it to the front of the rear axle. then push the drive shaft tward the trans mition may need t use a pry ber to break it away from the axle then pull it out of the trasmition. you may want to put a bucket under the rear of the tranny as it may leak some fluid.
Old Jun 21, 2009 | 02:37 PM
Bern_F150_4x4's Avatar
Bern_F150_4x4
If your going to have the DS out for an extended period of time, I would reccomend getting a spare slip yoke from the JY. Install it after you remove the DS to keep the fluid in and crap out of your trans. You could retain the "towing yoke" in the trans with a bungee cord. Just a thought.
Old Jun 21, 2009 | 02:43 PM
quicklook2's Avatar
quicklook2
mark how it went together before taking it apart.
Old Jun 21, 2009 | 02:48 PM
1994 F250: 351, C6's Avatar
1994 F250: 351, C6
Just pull the four bolts on the pinion and leave the driveshaft connected up front and bungee chord (or chain) it to something solid and out of the way under the truck. This allows you to keep all of your tranny fluid. I am a tow truck driver and this is how we pull driveshafts for towing.
Old Jun 21, 2009 | 03:06 PM
Ole'Blu's Avatar
Ole'Blu
Thanks to all for the input!!! I'll be on the road in three days!!!
Ole' Blu
Old Jun 21, 2009 | 03:25 PM
quicklook2's Avatar
quicklook2
tape the cv caps on so they don't vibrate off.
FXDawg
114
Nov 30, 2016 06:23 PM
suburbanM3
Electrical Systems/Wiring
Apr 20, 2014 12:19 PM
ultraboyus
Mar 4, 2014 02:26 PM
Ole'Blu
Aug 11, 2013 06:27 PM
Per4mance
Jul 6, 2013 12:04 AM
