Emergency Brake dash light
Old Jun 20, 2009 | 10:16 PM
Billyclub's Avatar
Billyclub
So the other day I'm driving down the road and my dash light for the Emergency Brake comes on telling me the brake is on. I look down and say to myself "No it's not". I pull over and push the brake down and then pull the release handle and the light goes off. Then a couple days later it does it again, did the same thing again and all is good. then it does it again a couple of days later again. Of course my 8 year old son chimes in and says dad, why are you driving around with the emergency brake on for?
Why does this keep happening, is there a adjustment that I can do to get rid of this issue?
Old Jun 20, 2009 | 10:46 PM
zx250's Avatar
zx250
Of the next Riffraff East
Check the cheesy little plastic switch on the emergency pedal. It's at the top of the assy. You might try spraying it with contact cleaner.
Old Jun 20, 2009 | 11:32 PM
duck fan's Avatar
duck fan
Because racetruck
Mine does it sometimes too as does Nolan's (4inchlovin). Seems with age the pedal gets loose and does not push the sensor up very well. If I just push my pedal to the left with my foot it shuts the light off.
Be thankful you do not have a manual trans. There is a chime that goes off non stop when you are in motion with the brake "on".
I have been meaning to get under the dash and tighten it up. Whoever gets it figured out should take some pics and do a write up. As our trucks get older this should be a more common issue.
Old Jun 21, 2009 | 08:49 AM
pbr man's Avatar
pbr man
You might check the rubber bumper on the brake pedal. Mine was cracked and when I would release the brake it would look like it was touching the switch but it was moving to one side enough to not turn the light off.
Old Jun 22, 2009 | 05:55 PM
Billyclub's Avatar
Billyclub
Thanks for the help everyone. I'll get under the dash when the rain stops. I'm growing gills it's been raining so much.
