4WD Problems - 1982 F150 I6
So I'm moving along in 4WD and I get a massive "clunk" (feels like a slip followed by a slam). The truck then keeps on trucking in 4WD like nothing is wrong....until another clunk.
In 2WD...truck runs fine. I never feel this "clunk" or "slippage".
Any thoughts on what might be going on?
This is going to be my hunting and wood-getting truck. So I need 4WD to work properly.
It felt like the front. I mean, I fully expected to look behind me and see something on the ground...it was that loud and jarring.
But yeah, to answer your question...I'd say mor like the front.
Have you looked at/inspected your front axle & driveshaft U-joints? Next thing to
come to mind is a front hub but I've never experienced a failure in one myself so
can't equate those symptoms. Finally, there's the transfer case (athough that's
more in the middle of the truck, its forces are transferred to the front).
Yes, are you running on dry pavement when this happens? If your tire sizes are not close, it will build up stress in the driveline till it suddenly releases it. One of those times it might break something.
Drive on a gravel road in 4wd and see if it goes away.
Yeah, you know...i didn't even look at the tires to make sure they were EXCACT. Thanks for the suggestion.
Yes, this was on dry pavement...which I normally would not have the truck in 4WD during. However, I was towing my other car from a wet muddy field...yada yada yada...then onto the dry pavement and I didn't want to stop.
While I have your attention, do you have any advice on a Suspension Lift Kit Size? I don't want to run into alignment issues. I was thinking the 4" suspension from Rough Country.
Also...it looks like I need to replace the exhaust on this thing. If you have suggestions there on what to replace with, I'd like to hear them.
Thanks
Thanks
Did another test today.
Hubs engaged + 2WD = No large jarring force.
Hubs engated + 4WD = Repeat of large jarring force. (also, this seems to occur with 2 "jarrs" at a time).
I had a buddy ride with me today, that is more mechanically inclined that me. He seemed to think it might be the chain slipping in the transfer case.
This isn't normal. I don't think it has much to do with driving it on dry pavement or not. It did the same thing down a gravel / dirt road.
Also...I live at 6300 feet, in the mountains of Idaho. I can't be worried about whether I'm in 4WD for 1/4 mile on dry pavement between sections of compact snow and ice.
Anyhow, if anyone has seen this problem before, let me know. It looks like I'm getting into a Transfer Case overhaul at this point.
On my old 80 I stripped the splines on the slip joint going over to the passenger side front wheel. I knew it was wore out, and all it took was me getting hung up in a big snowfall to strip it. I could not work on it right away, but driving along in 4wd you could not tell anything was wrong. You could only hear it grinding and slipping when the going got tough and I need the front wheels to pull.
Yeah...the '82 F150 is a new truck for me. I really just bought it for getting back and forth to work, getting wood, and hunting. Plus I thought it might be kinda fun to work on and learn a few things along the way.
I got tired of beating the heck out of my '05 F250 Diesel.
