aod overdrive
Old Jun 20, 2009 | 05:35 PM
rustee90-150's Avatar
rustee90-150
aod overdrive
i have an 89 fullsize bronco with 5.0 litre. i just put in another aod tranny it works fine but it dosent seem to want to go into overdrive. i have the vehicle at 60 mph where od should engage but i have to lightly jab the throttle and let off then it will drop into od and drive fine. its also droping into reverse hard. any ideas ?
thnxs
Old Jun 20, 2009 | 06:09 PM
85e150's Avatar
85e150
Did you adjust the linkage and TV cable?
Old Jun 20, 2009 | 06:55 PM
rustee90-150
i did set it i had help from one of the guys at work , i work at a ford dealership but im just an apprentice in my first year. i know we didnt set it the way the book says i held the outer arm on the tranny all the way back "towards the rear" then he locked the cable so im gona readjust it according to the book monday . but do u think if the tv cable is out of spec that it could cause the hard reverse and wierd overdrive ?
Old Jun 20, 2009 | 07:14 PM
85e150's Avatar
85e150
That guy at work, keep him away from your truck.
Yes, a TV cable adjustment out of whack can cause trans failure, so DO NOT DRIVE IT till you can get it fixed.
Scroll down on the "Browse by product type", open it and find 'Ford TV cable instructions'
http://www.tciauto.com/Instructions/Instructions.aspx
Old Jun 20, 2009 | 07:20 PM
rustee90-150
ok hopefully i haven't already pooched it i may have drove 3 miles in total.
Old Jun 22, 2009 | 06:06 PM
rustee90-150
well i reset my tv cable now it shifts into overdrive on its own more like it should thanks alot for the help.
Old Jun 22, 2009 | 06:25 PM
85e150's Avatar
85e150
Glad to hear it.
Good luck with it.
