difficulty level COPs
Old Jun 20, 2009 | 11:13 AM
jamesblonde82's Avatar
jamesblonde82
how hard is it to replace the spark plugs AND coils on my 2000 V10 X?
and how necessary is it to replace them all, with 90k miles?
reason i want to do it is because when i crank it up it starts but almost fumbles into life at times runs rough for a few seconds, then smooths out and is fine. it's been doing this for about a year and hasn't gotten any worse or better. there is no CEL, and when i've had the codes checked, (by someone else) they say there's no codes at all. this has been a mystery problem for a year now and i'm thinking its a COP gone halfway bad or something.... anyone else want to chime in? please!
Old Jun 20, 2009 | 11:37 AM
Monsta's Avatar
Monsta
Sit. Stay.
Have you tried cleaning your Mass Air Sensor? It is right after the air filter.
Old Jun 21, 2009 | 09:14 AM
TeamMudd's Avatar
TeamMudd
as for the coil on plug question....... the drivers side will be pretty easy for ya! the rear 2 on the passenger side at a PAIN IN THE ****!! but still doable!
it's been a few miles since i changed them in my F250, but i think it's a 7mm to take the COP's loose, then you can take the COP off the plug. try to pull on the boot more than the plastic.
once you take your COP off, you'll need at least a plug socket, ratchet (1/4 & 3/8 just in case), an adapter from 1/4 to 3/8 (once again just in case), about a 3" extension and a swivel on hand as well. then find you either a in/lb or ft/lb torque wrench. i torqued my plugs to 14ft/lbs............
there was a debate on what Ft/lb to torque them too a while back in the V10 forum, some said 11ft/lbs, some said 30 ft/lbs.......... i don't have the link, but there was a link posted saying 14ft/lbs........... that's what i torqued them too. and put just a DAB of anti sieze on the plug threads.
when cleaning the MAF take you some brake cleaner/carb cleaner, take the MAF out of the truck. spray the cleaner on the small wires let it set for a few seconds, and repeat 2-3 times, then if you feel brave enough and don't use any preasure....... take a Q-tim and GENTLY, and i mean GENTLY run it over the wires. then reinstall.
Old Jun 21, 2009 | 02:47 PM
Cardiac69's Avatar
Cardiac69
Might also check the idle air control (IAC) valve...
Old Jun 21, 2009 | 08:23 PM
m350's Avatar
m350
x2 on the IAC valve,,,there is a pic of it in FTE somewhere,,,maybe try a search on it.
Old Jun 21, 2009 | 08:28 PM
sddesigns's Avatar
sddesigns
FTE Leadership Emeritus
FTE Emeritus
Here's the spark plug change thread:
https://www.ford-trucks.com/forums/4...th-photos.html
Old Jun 21, 2009 | 10:28 PM
sddesigns's Avatar
sddesigns
FTE Emeritus
Here are some threads referring to the IAC valve location and removal description:
2003 Ford F250 4x4 - V10 IAC
https://www.ford-trucks.com/forums/5...rsion-v10.html
Old Jul 15, 2009 | 01:44 PM
PerfDistIgnition's Avatar
PerfDistIgnition
FTE Sponsor
A coil that is "on the blink" will not always give you a CEL.
Our new Ford COP’s, the Sultans of Spark(S.O.S.), have
been designed with both durability and performance in mind.
Please see them at:
http://www.performancedistributors.com/soscoils.htm
Quality was the main feature we stressed when we went to the
drawing board on these coils.
By the way, for those of you who only need to replace a defective coil,
our SOS Coils are available separately.
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
Old Jul 15, 2009 | 01:52 PM
Monsta's Avatar
Monsta
Sit. Stay.
So mixing the SOS COPs with stock COPs is okay?
Old Jul 15, 2009 | 01:56 PM
PerfDistIgnition
FTE Sponsor
Yes, that is no problem.
__________________
FTE Sponsor
