Possible engine swap?
Old Jun 19, 2009 | 06:35 PM
370f600's Avatar
370f600
I have a 1981 f600 with the 370 and its not running that great, i have an old box truck with an international dt466 diesel i would love to have it in my dump truck, has anyone seen a swap like this? and how would i go about getting it done
Old Jun 19, 2009 | 10:39 PM
Diesel_Brad's Avatar
Diesel_Brad
I have never seen a medium duty IH engine in a Medium duty Ford truck but any thing is possible.
Take everything from the IH truck and put it in the ford gasser
Old Jun 19, 2009 | 10:54 PM
Franklin2's Avatar
Franklin2
Lots of fab work probably. Isn't the 370 related to the 460?
Old Jun 19, 2009 | 10:58 PM
85e150's Avatar
85e150
Make a list and check it twice. Lots to fool with in a conversion like this. It's the little things. Cooling, exhaust, mounts, fuel system, electrics, gauges. Will it clear the steering box, do the manifolds dump out into the frame rails, what trans will work, etc.
The idea is sound, but work it out system by system, and measure twice etc.
You might find fixing the 370 or getting a 429 more in line with not just the money part of this, but the time investment.
Good luck, and perhaps we will get a post from someone who has done a similar swap.
Old Jun 19, 2009 | 11:03 PM
Diesel_Brad
Yes. the 370, 429 and 460 are all i the same family. I am still confused y the 460 was never offered in a medium duty truck
Old Jun 21, 2009 | 10:04 AM
FESuperDuty's Avatar
FESuperDuty
The IH engine will be a lot longer than your 370. Depending on how high the engine sits in your Ford, the "doghouse" you will have to build inside the cab may interfere with the dash. This will also move the transmission back several inches. You will have to think about clutch linkage unless you are running an automatic. There will definitely be a lot of custom fabrication on a swap like this.
acarter92
Sep 10, 2013 07:20 PM
uniequipment
Aug 31, 2009 06:25 PM
ddsprint
Jun 27, 2008 07:44 AM
BigBlockBill460
Jan 17, 2004 06:59 PM
gabraham
Jun 16, 2003 06:41 PM
