Differential fluid
Old Jun 20, 2009 | 09:41 PM
SmallBlockV8's Avatar
SmallBlockV8
Differential fluid
I have a 82 F-250 light-duty and the rear differential leaks. What weight and kind of fluid do you recommend? Also what kind of sealant would work the best and keep it from leaking again?
Thanks
Old Jun 20, 2009 | 10:38 PM
ctubutis's Avatar
ctubutis
80-90 gear lube (assuming non-limited-slip)
Also what kind of sealant would work the best and keep it from leaking again?Thanks
Assuming the rear cover here, Form-a-Gasket #2
http://www.permatex.com/products/Aut..._2_Sealant.htm
Old Jun 20, 2009 | 11:40 PM
Franklin2's Avatar
Franklin2
If you have a drip on the bottom of the differential, get some on your finger and smell it. It should really stink like it's rotten. If it does, then it is gear oil. But, any small leaks up front will also catch and drip off the diff too, so it could be motor oil or something else.
Old Jun 21, 2009 | 09:39 AM
SmallBlockV8
I think my differential is limited slip so should I use something different?
Old Jun 21, 2009 | 09:52 AM
SteveW09's Avatar
SteveW09
I put Redline 75w-90 in my Dana 60 rear end. I figured 3 bottles of that was about the same or cheaper than 3 bottles of regular gear oil and a bottle of friction modifier. Plus, there ain't much better in fluids than Redline.
Old Jun 21, 2009 | 10:17 AM
SmallBlockV8
Gear Lube
How many bottles of gear lube would it take to fill up my Dana 60 rear end with stock diff cover?
Old Jun 21, 2009 | 10:18 AM
SteveW09's Avatar
SteveW09
Almost three bottles for mine.
