P.C.V. Valve
Old Jun 19, 2009 | 11:04 AM
tralfamadorian's Avatar
tralfamadorian
P.C.V. Valve
I have a 1994 F250 w/ the 300. I got a new P.C.V. valve the other day. When I looked at the valva tht is on my truck, I noticed that there is one hose running from the valve, from the lower hole in the elbow. Should there be a second hose running from the top hole or is the top hole just some sort of vent or intake for air?
Old Jun 19, 2009 | 12:18 PM
Sycostang67's Avatar
Sycostang67
If your new valve has that dual elbow, it should come with a little plug to cap off the smaller port. Some vehicles will run 2 hoses, but it you only have the one hose, then just plug the other port.
Old Jun 19, 2009 | 01:06 PM
jas88's Avatar
jas88
Or you could take it back and get the same valve with a single port on the elbow.
Old Jun 19, 2009 | 01:57 PM
oldblu65's Avatar
oldblu65
I have a newly acquired 1996 F150 /4.9L and I'm kinda flying blind at the moment on various aspects of the truck . I have a new PCV valve to install but can't seem to find the old one ? Have been told it's on the back of the valve cover underneath the intake manifold ? Is that correct ? If so , why did the Ford engineers put so many things where they are difficult to access ? My guess would be they don't work on their own vehicles ? On a related matter , I replaced the thermostat yesterday and when I went to replace the two heater hoses , I realized I didn't know for sure which went where ? I know it's a 50/50 % shot at getting it right but I'd like to know if I'm correct . As you stand in front of the truck looking at the hoses , where they come out of the firewall , which ( left or right ) goes to water pump or to thermostat housing ?
