Trans Fluid looks Clear?
Old Jan 30, 2002 | 05:25 PM
lt's Avatar
lt
Hi guys, I have a 1990 F250 XLT, 351, with the E4OD trany and when I checked the trans fluid the other day,(hot and in Park) it looked clear. I even checked it twice. And I used an old white t-shirt to clear the dip stick. I had the trans fluid flushed last spring, almost a year ago-4,000 miles ago. What could cause this? I thought the fluid was to look a bright red. The truck has 126K miles on it.
Thanks for any help on this.....
Larry
Old Jan 30, 2002 | 06:15 PM
Boomer95's Avatar
Boomer95
Old Jan 30, 2002 | 08:29 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
That transmission fluid is worn out. It needs to be changed.
You are correct that it should be red.
Mark
Old Jan 31, 2002 | 12:10 PM
jim henderson's Avatar
jim henderson
Assuming your year does use Mercon, then yes, the fluid should be red and clear(ideal).
But if some one used the wrong frluid or if your year didn't use Mercon, then it might be yellowish clear.
But if it is light pink or almost clear, best bet is it is worn out.
Better clear than brown or black though.
Good Luck,
Jim Henderson
Old Jan 31, 2002 | 12:31 PM
Mark Kovalsky
A 1990 E4OD does use MERCON fluid.
It should be red.
Mark
Old Jan 31, 2002 | 12:45 PM
lt's Avatar
lt
Thanks Guys.... better to be safe than sorry. I will be changing it this weekend. And I checked the Chiltons manual, it said Dextron II Mercon also.
Thanks Again.
Larry
retiredsparky
Feb 12, 2014 08:00 PM
lharley
Jun 10, 2012 05:29 AM
Craven
22
Apr 11, 2006 07:04 PM
larry p
Jan 29, 2005 11:09 PM
donk
May 20, 2002 12:02 AM
