ticking time bomb???
Old Jun 16, 2009 | 05:05 PM
blackhullpirate's Avatar
blackhullpirate
I wanted to post a thread to see if anybody else was having the same issue as I with the 5.4L 24v Triton V8 in my 05 Expy. The engine has a light metallic ticking sound to it that corresponds with the speed of the engine. At first I thought it was coming from the tranny/torque converter but I was wrong. I took it to the Ford dealer and they showed me a TSB saying something about the valve lash adjusters and that's just the way they were supposed to sound. Well the ticking drives me nuts. I just don't believe that an engine should make metallic noises like that. Has anyone else had this problem? If so, was it fixable??? Thanks!
Old Jun 16, 2009 | 06:58 PM
madsonp's Avatar
madsonp
Piston slap, it's common with the 5.4. Nothing to worry about, but I agree it's irritating.
Old Jun 17, 2009 | 02:18 PM
Jeff Dodson's Avatar
Jeff Dodson
I have the same problem, i was told it has to do with some solinoids on the heads and is caused by the solinoids being clogged with sluge and using the wrong viscosity oil. I use 3/30 castrol synthetic. I was told that I needed to run Lucas that is compatible with synthetic oil to clean the engine and solinoids and then i have to run 2/20 conventional oil only. it has something to do with the motor not being able to keep the pressure up at idle. I am going to tey this and see if that makes it quit
BTW, Its a 2005 Expy 5.4
Old Jun 17, 2009 | 03:37 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
Alot of wrong info in here
The ticking "diesel" noise is caused by the Cam Phasers. The 04-05 5.4 3v motor have a problem with them. It is NOT PISTON SLAP...nor is it necessarily a sludge issue
Btw, only use 5w20 oil in the 5.4 3v engine. Anything else, and your are risking damage. Also, use the Motorcraft FL-820s Oil filter. Ithas an improved anti-drainback check valve...other brands of filters are substandard comparitively
A loud set of Cam Phasers can be annoying...but that aren't exactly bad either. Plenty of guys run 'em for a really long time without issue. But, they do occasionally fail prematurely
To fix, you are gonna spend several grand...so IMO, a replacement motor is a better more viable option. Especially if you already have higher mileage.
Old Jun 17, 2009 | 06:30 PM
Jeff Dodson
These CAM PHASERS, are the things at the front of both of the valve covers. I have a friend, reputable mechanic, that said most of the time they cam be cleaned, worst case is to replace them. I was running Sythetic 10/30 but at his suggestion, I just changed to the 5/20 oil. he said drive it like that for awhile and it should quiet down. If not They may need to be replaced.
Old Jun 18, 2009 | 07:27 AM
Johnny Langton's Avatar
Johnny Langton
It's not always the phasers or piston slap.It could be a defective follower. Replacing a bad follower is about $20 in parts. Leave it alone until it fails, and it can cost you far more than $1000.
Read here:
https://www.ford-trucks.com/forums/7...r-tapping.html
JL
Old Jun 19, 2009 | 02:36 AM
blackhullpirate
Thanks
Thanks man. Took it to the shop today, it was the phasers. Good thing the extended warranty covers it! That's a pricey job.
Old Jun 19, 2009 | 03:19 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
that is what we are here for
so they are covering it under warranty? wow, good for you then
coolidge54
Mar 8, 2019 12:03 PM
Gloz
1997 - 2003 F150
Dec 13, 2015 06:45 PM
Buck268
2009 - 2014 F150
Nov 21, 2014 03:53 PM
Munkey
Modular V10 (6.8l)
Jan 6, 2004 06:39 AM
