Check coolant now!!
Old Jun 29, 2009 | 05:41 AM
  #31
12ozd's Avatar
12ozd
Originally Posted by Workin4ALivin
12ozd, you might be able to use your units per gallon strips. A little bit of math will convert them to ppm.
1ppm = 1mg/L
1gallon = 3.78541 liters
1ppm = 3.785mg/Gal
I wonder how much a "unit" is?
Old Jun 29, 2009 | 11:20 AM
  #32
Workin4ALivin's Avatar
Workin4ALivin
Your supplier should be able to tell you, or if you have both types of test strips test the same coolant and see what each one reads.
Old Jun 29, 2009 | 02:44 PM
  #33
BPofMD's Avatar
BPofMD
Veteran: Navy
Originally Posted by bismic
Let me know if you would like a copy of the TSB.
Thanks, guess my name was last on the postal delivery list....got it Saturday!
Old Jun 29, 2009 | 10:05 PM
  #34
Mulepick's Avatar
Mulepick
Here's the TSB:
http://www.fcsdchemicalsandlubricant...d/tsb/0985.pdf
Here's what 328-00001 looks like:
http://www.acustrip.com/specs/3-wayaf.html
Nitrate is NO3, Nitrite is NO2, and, lastly, here is a good article for those who want more science:
http://www.allbusiness.com/construct...6340528-1.html
Old Jul 2, 2009 | 02:13 PM
  #35
KRDiesel's Avatar
KRDiesel
My local dealer tested my truck for free, my nitrates were below the limit and had the full system flushed for $150. If you have a relationship with a good dealer they should test it for free. The parts guy told me that they are receving the strips and will be saling them for a buck each.
Old Jul 2, 2009 | 02:51 PM
  #36
12ozd's Avatar
12ozd
FWIW if the nitrite level is low,you can add an additive to bring it to specs.
No need to pay for a flush and fill.
(unless it's needed anyway)
Old Dec 12, 2009 | 05:18 PM
  #37
Catfish_Man's Avatar
Catfish_Man
Bottom line is that Nitrate testing of the coolant is not part of what your original maintenance requirements said yoiu needed to do.
The letter from Ford means nothing and was only sent apparently to a few 6.0 owners.
What Ford was up to, we don't know.
After I go0t the letter, I took mine in to Ford and had them do a coolant system flush and change at my expense at 39,000 miles. If there are any other issues regarding coolant that they think contruibuted to a future possible engine failure then it's Fords problem and nobody elses.
I don't put nitrates in my coolant and wouldn't know how anyone might do this! If nitrates get in there, then it's an engine problem and not my fault that is that!
Supprised that some got the letter and some not. I think maybe because their records showed you had a certain procedure done and they had remaining issues that they may not have done things like they should have been done to begin with.
Maybe just to scare us or probably to cover their servoice tech's butts at the owners expens????
Old Dec 12, 2009 | 05:46 PM
  #38
danosll's Avatar
danosll
Trailering
I was told the same thing from my friend who has a high level mangement position at ford that ford is denying warranty claims like never before(once had a complete front end changed on an explorer that had been changed due to an accident and the dealer was totally aware of it because I told them so there wouldn't be a charge back on me) ford inspectors are showing up much more frequently. and I am haveing a similar problem check my post
https://www.ford-trucks.com/forums/9...anty-work.html
Hunter40
6.7L Power Stroke Diesel
22
Mar 6, 2016 04:54 PM
p_arbor
Jan 14, 2014 10:56 AM
j klug
Sep 12, 2012 12:11 PM
Diesel32
Aug 24, 2010 11:18 AM
bismic
Aug 18, 2009 12:03 PM
