pick up a 92 f150 4.6I6 for 300.00 bucks plus tow 82.00 wasnt running so pulled codes replaced BP/Mass sencer runs great
was told the tranny was bad alkinds of noise when clutch is out no noise when pushed in
truck will drive they had a tranny they got for it in the bed
Old one numbers are F2TA KA AS16558
New ones numbers F1TA HA A18SS56
The only dif I can see is old donts have a place for speedo and new one does
maybe change tail houseing or just leave the speed o peice in the new one tranny code on door is M
ok thanks again
Phil
Not an expert but trans code M is the Mazda 5-speed. The truck probably uses a speed sensor on the rear diff so no need for one on the trans.
You should post this on the `87-`96 F-Series page for some opinion.
