red brake light
Old Jun 15, 2009 | 10:17 PM
jcahicks's Avatar
jcahicks
red brake light
Hey guys I've got a 71 Ranger, 360 4x4,4spd,drum brakes. The red light came on the other day so I did some checking around, found a small leak in one wheel cylinder, all the shoes were ok, I did replace the master cylinder cause it was the original one, thought that might be my problem. Bled all the lines really good, but the red light still wont go away. what else can I check I even have adjusted the ebrake today and still no luck? Does anyone have any ideas? Thanks
Old Jun 16, 2009 | 08:50 AM
Red69's Avatar
Red69
I always have trouble getting the light to go off when bleeding. If there is an imbalance of pressure between the front and rear it comes on. I don't know if there is a better way, but I have my wife push the brake and I go from font to rear letting a little pressure off the bleeder until it stays off. Sometimes it take four or five attempts. You probably should check the brake adjustment also to make sure all four sets of shoes are out close to the drum.
Old Jun 16, 2009 | 06:53 PM
jcahicks's Avatar
jcahicks
Ok I will try that thanks for the info.
