Anyone know how to change to crankcase position sensor on an 07 6.0L. it cranks and wants to start but doesnt and code P2617 came up, i know the part is cheap but where is it and how?
Crank sensor is located on the bottom right (passenger side) of truck. It is under the A/C compressor up against the block. You need a 15mm socket to remove the bolt for the ground wire. Then its a 8mm swivel and extension to remove the bolt from sensor. Then remove connector and sensor and replace.
