Bilstein Part #'s
Old Jun 15, 2009 | 10:39 AM
dvfd12's Avatar
dvfd12
Bilstein Part #'s
I'm confused! I'm getting 2 different part #'s from 2 different websites, and Bilstein's site isn't any help. I'm looking for part #'s for the 5100 series (don't want the baby blue and yellow look) - 02, 4wd, stock height.
Thanks
Old Jun 15, 2009 | 11:53 AM
F250_'s Avatar
F250_
This is the best info I can find... hope this helps....from ShockWareHouse.com... http://www.shockwarehouse.com/index....cted_year=2002
5100 - Racing Series
FRONT Shocks
F4-BE5-A464-H5 Front 1 $75.70 each
Free Shipping
Important: Units for trucks with double shocks. See Bilstein for details. Compression bump stop on chassis may need to be modified to prevent damage to the shock absorber. This is standard when placing longer shocks in the stock location.
REAR Shocks
F4-BE5-6246-H6 Rear 1 $75.70 each
Free Shipping
Important: Use on 1999 - 2004 models with up to 2-inches suspension lift. On 2005-up models, use on trucks with a 2 to 4-inch suspension lift. Compression bump stop on chassis may need to be modified to prevent damage to the shock absorber. This is standard when placing longer shocks in the stock location.
Old Jun 15, 2009 | 11:59 AM
dvfd12's Avatar
dvfd12
Thanks for posting that.
That's one of the sites I found too, but when I called them they gave me part #'s BE5-2818 and BE5-C296. 4wheelparts gave me BE5-6246-H6 and BE5-A464-H6. I'm not real sure what the differences are.
Old Jun 15, 2009 | 12:10 PM
F250_'s Avatar
F250_
Something's up with what they told you on the phone... either they misunderstood you or mis-quoted the part numbers or you might have mis-understood the numbers they quoted.
The"2818" is the standard HD yellow and blue shock you're NOT wanting, and the "296" number is for either a Jeep or Freightliner. I got that info by searching their site with those part numbers.
The part numbers from 4wheelparts match exactly the schockwarehouse.com numbers I listed above in my first reply, and I believe that is exactly what you need based on what you've told us thus far.
Old Jun 15, 2009 | 12:20 PM
dvfd12's Avatar
dvfd12
OK I'll try those. Thanks!
Old Jun 15, 2009 | 12:24 PM
dvfd12's Avatar
dvfd12
Sorry one last thing. When I search part # F4-BE5-A464-H5 at Bilstein's site it shows BILSTEIN - LIFTED TRK 5100 10"TRVL 170/60 * Position: Front /Rear * Setting: 5100 Series
Old Jun 15, 2009 | 05:35 PM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
I'm not sure about the part #s but I got the best price and PHENOMENAL service from TruckToyz Performance
CLICK HERE for the thread I made about when I put mine on
Old Jun 15, 2009 | 07:22 PM
dvfd12's Avatar
dvfd12
Brendan,
Did you have any issues with the rear shocks being designed to work with lifted springs?
I was wondering if I could use the same ones?
Old Jun 16, 2009 | 10:10 PM
kupaa's Avatar
kupaa
OK,does this sound right for my truck.It has a 2.5 inch leving kit.This is the part# that i got but its ony for a 2 inch lift,does it make that much of a difference if a have a 2.5 inch lift.F5-BE5-6246-H6
cmsslates
Jan 4, 2015 10:48 PM
JimDev57
Apr 1, 2013 06:43 AM
Part-Timer
6.7L Power Stroke Diesel
Jul 19, 2011 12:19 PM
DIXIEDOG1
Mar 26, 2011 08:46 AM
CAT_man_963
18
May 14, 2006 06:11 PM
