E4od headaches
Old Aug 4, 2008 | 03:25 PM
keitholson1983's Avatar
keitholson1983
E4od headaches
ii have a 78 bronco that i swaped a 92 f350 into. my bronco now has 7.5 efi an e4od and a borg-warner 1356 with a PULSE sensor in the tail shaft from an 80s bronco. i was hopeing that the VSS and the PULSE would be the same. not the case. since i dont know of a VSS ever being in a 9" im stumped as to what i should do. does anyone know if i can reprogram my PSOM to work with PULSE or can i chage the sensor to VSS in the tail shaft or maybe even put a VSS in my 9" ??? i dont think i have any room for the bigger pinion of the sterling that was under the F350. somebody please help i dont want to drive my bronco in second gear forever
Old Aug 4, 2008 | 03:57 PM
danr1's Avatar
danr1
Sounds like you created yourself a monster, Best bet may be to just go with a after market tranny controller.
Cheapest route? I doubt it but may be the only way to control it in that year bronco.
Baumannator TCS Electronic Transmission Control System
Old Aug 11, 2008 | 01:34 AM
keitholson1983
i fingerd it out well steve from electro speedo 888-545-7496 helped. with his instruction i jumped two wires and my e4od shifts 150$ and he can even make my speedo work. any body got 150$ i can borrow??? anyway the PSOM divides the signal from the VSS into much closer to what my PULSE sensor puts out so he said jump the output from sensor to the input into the computer and it worked. thanks every body
Old Aug 11, 2008 | 01:52 AM
keitholson1983
that baumanator looks cool maybe ill get one when i start makin some $$$ again
Old Aug 11, 2008 | 11:07 AM
andym's Avatar
andym
Wow, that's really cool. Can you tell us what two wires you jumped?
Old Jun 15, 2009 | 01:47 PM
keitholson1983
#4 and #9 pins red and black with yellow stripe i dont know how well it will work with vss input tho
