how do I get the hub off?
Old Jun 15, 2009 | 03:05 AM
Towmanjbo's Avatar
Towmanjbo
just forget that the pic says it is a Auto locking hub, it's the same.
Old Jun 15, 2009 | 08:08 AM
ptex's Avatar
ptex
Ok so I found my manual, it shows a axle with a shock near the pitman (sp?) arm and I don't have that, should I?
Old Jun 15, 2009 | 08:09 AM
ptex's Avatar
ptex
oh btw it's so embarrassing I'm driving a Chevy loner right now.
Old Jun 15, 2009 | 09:16 AM
ptex's Avatar
ptex
I hope I have the right ball joints. Which front axle does it have? D44
Old Jun 15, 2009 | 11:00 AM
Sycostang67's Avatar
Sycostang67
After looking at the first pics you posted, I 'm pretty sure you have a D50.
Old Jun 15, 2009 | 11:32 AM
ptex's Avatar
ptex
How about this
Old Jun 15, 2009 | 11:45 AM
andym's Avatar
andym
I agree. Looks like a Dana 50 to me.
Old Jun 16, 2009 | 04:13 PM
ptex's Avatar
ptex
Ok now how do I get the outer race? off? I took off the 8 bolts and I have put the that part that uses the special socket back on and I have been trying to pull, hit it off with a gear puller and a big hammer for the last 4 hours. Am I missing something?
Old Jun 16, 2009 | 04:51 PM
andym's Avatar
andym
What are you trying to get off? The races are inside the rotor, so I doubt that's what you mean.
Old Jun 16, 2009 | 08:31 PM
ptex's Avatar
ptex
I got it finally, maybe its called a spindle. Anyway I beat with a BFH and a block of wood for about 3.5 hours. That sucked. Now day 3 I'm trying to figure out how to press in the upper ball joint. I have the press tool but it does not seem big enough.
Old Jun 16, 2009 | 09:17 PM
Diesel_Brad's Avatar
Diesel_Brad
Make sure you didnt oval out the spindle by beating on it
Old Jun 17, 2009 | 04:41 PM
ptex's Avatar
ptex
Why is this so hard?
Old Jun 17, 2009 | 05:29 PM
  #28
Blue Rebel's Avatar
Blue Rebel
Cuz your trucks 21 years old. that spindle probably hasnt been off in the last 10 years. what tool did you get? They make 2 versions of the tool, one is made primarily for ricers, the other for larger cars and trucks.
Old Jun 17, 2009 | 05:54 PM
  #29
McLeod's Avatar
McLeod
This is what I have:
- Harbor Freight Tools - Quality Tools at the Lowest Prices
and should well exceed the size required for any full size pickup.
Not only does it work on ball joints, I use it for u-joints and suspension pivot bushings.
Old Jun 18, 2009 | 05:03 AM
  #30
ptex's Avatar
ptex
now I can't get the upper ball joint pressed in, I'm going to take it to a local shop and see if they will press it in.
