No 2nd in E4OD
Old Feb 20, 2002 | 03:42 PM
orange peel's Avatar
orange peel
No 2nd in E4OD
Old Feb 20, 2002 | 03:50 PM
jkiser96's Avatar
jkiser96
Post No 2nd in E4OD
I have a 96' F-350 4x4 with 145,000 miles & just lost 2nd gear in my E4OD. I took off from a light & it run thru 1st gear but when it hit 2nd it acted like there were no gears in there for it to catch on,the tach jumped upuntil I feathered it into 3rd & it was fine after that. Does anyone know of a good reman or someone who rebuilds these. I have priced Jasper & they want $2250 exchange.
Old Feb 20, 2002 | 05:53 PM
orange peel
No 2nd in E4OD
yep youll need a rebuild and yep that looks to be a normal price. might be kinda high though, try checkin around to make sure.
Old Feb 21, 2002 | 02:38 AM
madman666's Avatar
madman666
No 2nd in E4OD
That is way too much, this place has them for $850.
Go to both links
http://cgi.ebay.com/ebaymotors/aw-cgi/eBayISAPI.dll?ViewItem&item=1805461461
http://www.phoenixhardparts.com/Merchant2/merchant.mv
Old Feb 22, 2002 | 12:17 AM
90Bronc's Avatar
90Bronc
No 2nd in E4OD
Consider yourself lucky in a bad way. I have 70,000 miles on my 90 Bronco and my 2nd gear for my E40D just went. I assume you know that it was the clutch packs that went. You can verify that by smelling the fluid to see if it smells burnt and the ATF will be a darker brown/black/red color. If you pull the tranny pan there will most likely be a black residue in the pan. Anyway, I was quoted $2155 for a 3yr, 55,000 mile complete rebuild to $950 at Phoenixhardparts.com although the shipping is expensive plus they require a core for that price that you must ship to them so shipping cost adds up fast, I was quoted $1800 at another shop with a 6mo, 6,000 mile warranty. Good Luck.
Alex
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
