Yeah the one i saw at lordco was unpainted on all the fins so good there but the top and sides were black. Make them from all aluminum and leave them alone is what i would like to see.
Also to the original poster, since the diesel uses compression and engine heat for combustion, lower engine temps mean the engine efficiency is down when the temps are lower than 195 degrees.
So your power and fuel mileage should be suffering.
