dieseling
I can make short trips all day and the temp never gets to the "N" in normal range...but if i go for a run down the highway and get it up to "N" or "O" (NEVER GETS ABOVE THAT), it will diesel when i shut it off.
If i drop a bit of timing out it runs like crap.
Idle is set to 750-800 in "P", and 500-550 in "D"
After a highway run, if i let the motor run for a few secs, then shut it off it wont diesel as bad but you can still feel it trying to.
plugs, wires, cap, rotor, Ig module, carb rebuilt, and stator all have <2k miles on them.
Motorcraft stock replacement plugs, all other parts are stock replacement.
THanks, Rob
Does your motor ping at all? An '81 should have an EGR valve. Engines equipped with EGR are set up from the factory with lean jets and an over-advanced timing curve. If the EGR valve goes out under these conditions, the combustion chamber temperatures will increase (has nothing to do with the temperature gauge on the dash). If this happens, the motor is much more likely to diesel. I ask if it pings, because pinging and dieseling often go hand-in-hand. However, even if it's not pinging, it can still diesel as I've described.
Other common causes of dieseling include high curb idle and a vacuum leak.
I will drop the curb idle back a bit and see it that helps...
what does the anti diesel solenoid look like, and where is it located?
HTH
rikard
You're going to fight the dieseling problem for as long as you're running without EGR, unless you retune the motor with an adjustable vacuum advance, different mechanical advance weights and springs in the distributor, and different size jets in the carburetor. However, this is going to be a painful trial-and-error process that will, at best, bring your performance back to where the engine was before you started ripping stuff out. The anti-dieseling solenoid can help, but the fact is, if you're running an EGR engine without EGR, it's going to diesel and ping every chance it gets.
FYI, removing EGR is a waste of your time and a step backwards. It's a common misconception that EGR is "smog junk." It cools the combustion chamber by displacing air\fuel mixture with inert exhaust gas. This does not hurt performance at all and in some cases can actually increase gas mileage. I have no idea how this myth got started about EGR robbing your motor of power, but who ever started the rumor years ago was very misinformed.
I think a better alternative would be to have your distributor re-curved.
Remove your distributor and take it to a speed shop.
I found it kind of funny when I took mine in to have it tested and re-curved.
When I told him it was off of a 300 I6, he gave me the reaction of-
"Ahh.... well.... ok..... ahh.... whaaa....?" It was a speed shop, after all.
Anyway, this is the best way to know what your putting back in your truck.
If you find a pre-smog distributor,... then you have a pre-smog distributor.
What does that mean? I dunno.
If you have your distributor spun and checked,
you'll have numbers to use for further diagnosis.
If you go this route, leave your vacuum advance on your distributor.
They will check that for you also, telling you how much
your system is retarding your ignition at any given vacuum pressure.
I don't know what a "new" pre-smog distributor might cost you.
The checks and adjustments I mentioned above will probably cost you less than $50.
Let us know what happens,
Murph.
P.S. Then you can look into your carb jets.
P.P.S. Do you still have those emissions components to reinstall?
P.P.P.S. Yikes, good luck!
It's much easier to go back to an EGR setup. A new valve and ported vacuum switch will cost less than anything you'd have to do involving the timing curve. I imagine you still have the spacer plate and manifold pipe installed. Cleaning out the spacer plate wouldn't be a bad job. Personally I think this is the most straightforward, direct solution to the problem.
Don't forget to check for vacuum leaks as well. I'd do that first just to eliminate anything obviouis. See if you can lower your idle speed some as well. But at the end of the day, an EGR motor missing the EGR valve is just asking for pinging and dieseling problems. If you can get the motor to stop dieseling without fixing the EGR system as I've described, then you should probably buy a lottery ticket while you're on the lucky streak.
