Does anybody know off hand the tooth count for a manual transmission 4 speed? Its from a 68 F 250 with a 302 bolted on. Im trying to find a starter that will fit and not drag. This starter cannot be shimmed so is there another way to stop it from dragging?
Its from a 68 F250 with a 302 bolted on. Im trying to find a starter that will fit and not drag. This starter cannot be shimmed so is there another way to stop it from dragging?
F Series Trucks:
302 engines were not factory installed in F250's until the 1980's.
302 engines were not available with 4 speed manual transmissions until the 1980's.
The number of flywheel teeth is specific to certain engine sizes.
