help... drivetrain trouble
Old Feb 28, 2002 | 04:35 PM
Boss300's Avatar
Boss300
Hey Ford Men,
I have a tink, tink, tink sound coming from underneath my truck when I accelerate at slow speeds. My truck has a Ford 3.03 3 speed manual in it. I looked at the slip yoke and it is loose because I can move it up and down some in the transmission. Also, the rear seal around the slip yoke has started to leak a little oil. My question is have any of you guys ever had to replace a slip yoke or the bushing inside the tailshaft that supports it? And do my problems sound like they are slip yoke or U-Joint related?
Thank you very much,
Josh Payne
Old Feb 28, 2002 | 05:32 PM
FortyFords's Avatar
FortyFords
Sounds like your not having a good day.
yes, its a 2 fold situation you have
The rear bushing and front yoke will
wearout if the u-joints start to wear
And the u-joints will wear if the rear bushing is sloppy,thus this causes the rear seal to leak,are you following this,because I ramble somtimes
Oh ! yes I have changed the rear bushing in cars and trucks you need a special tool to do it.also you can get that tink ,tink ,tink sound from the rear diff (having to much backlash in the gears)when you take off from a dead stop.
Hope this helps!
Rich
Ford Trucks Built Tough!
not with rocks
Watch out "X" Mayor of Truckville
Old Feb 28, 2002 | 05:52 PM
RE_SPEED_FAB's Avatar
RE_SPEED_FAB
ritelec
15
Dec 12, 2014 06:45 AM
Arrowman400
Modular V10 (6.8l)
Jan 24, 2008 02:56 PM
Brother65
1983 - 2012 Ranger & B-Series
Mar 1, 2006 09:42 AM
Boss300
Mar 2, 2002 12:18 AM
red68ranger
May 18, 2000 04:05 PM
