Little cooling problem-
Old Jun 12, 2009 | 11:12 PM
Handegard's Avatar
Handegard
Ok.
1985 F250, fresh 466 rebuild. Cooling system is bled, no doubt about it.
Symptom- If a thermostat is installed, it overheats. This occurred last year, and my boss and co-works looked at it (I'm a auto-tech) and the conclusion was the radiator was slow flowing, probably due to sealant the old owner added. Water pump was replaced just prior to the rebuild, and multiple thermostats were tried. Take the t-stat out, runs cool but ok.
So, I'm planning to go on a ~500 mile trip, to go pick up my boat from my Uncles tomorow, so I bought a new radiator and installed it today.
It heated up pretty quick, an I'm going to test drive it now. I'm hopeing when it is moving it won't overheat.
What do you think? All I can imagine is if somehow the water pump isn't flowing enough? I just don't know? I'm going to take a drive, and if it over heats, pop the t-stat out along side the road...
Old Jun 13, 2009 | 07:26 AM
uncle.stosh's Avatar
uncle.stosh
I wouldn't want to chance it overheating and "pop the t-stat out along side the road". You could ruin your engine very easy that way, and it's a good way to get burned.
I would find the problem before you leave.
Do you have a good fan and shroud in place?
Old Jun 13, 2009 | 09:28 AM
Franklin2's Avatar
Franklin2
How do you know it's overheating? I would not go by the sorry factory gauge. Does it only overheat sitting still, or overheat on the road?
Old Jun 13, 2009 | 03:04 PM
Handegard's Avatar
Handegard
I wouldn't let it overheat. I just mean that if it doesn't seem to stay cool, I'll take the tstat out.
The fan shroud is whole, and the fan blows a storm.
Admitedly, I'm going off the stock guage. But the heat in the cabin is HOT. And the guage spikes to the L in Normal in just but a minute or two...
I suppose I'll go stick my thermometer on it and see what it says..
Old Jun 13, 2009 | 10:19 PM
FESuperDuty's Avatar
FESuperDuty
If there's any doubt about the accuracy of the stock guage, stick an aftermarket mechanical guage in it just to check. Did you do your own engine rebuild? Is it possible that you have one or both head gaskets on backwards? (with the water passage at the front of the engine instead of the back?)
Old Jun 15, 2009 | 01:13 AM
Handegard's Avatar
Handegard
It's a little odd now..
I brought along my laser thermometer, and just kept checking it. It never actually overheated, and the funny thing is, after a bit of driving (I did about 500 miles since yesterday, drove across the state, and towed a boat back) it seems to be working ok. The gauge climbs abit when I let the truck idle, but it doesn't seem to be a problem.
I did however get pretty bad gas mileage, worse than I expected. I haven't done the math yet, but I think I got about 6mpg... I was shooting for at least 8 if not 10...
Old Jun 15, 2009 | 08:55 AM
Franklin2's Avatar
Franklin2
I would go ahead and buy a nice set of gauges and mount them under the dash. I prefer mechanical type.
Of course your engine is a little tight since it's just been rebuilt, and needs to be broken in. After 500 miles, you should be loosened up a little bit, and I would get under the hood and re-tune the engine again. I would double check the timing, and maybe edge it up a little bit, and check the idle mxture screws on the carb again.
Get a timing light and while pointing it at the damper, and with the engine revved a little bit, plug in and then unplug the vacuum connection on the dist. The timing should jump up when you plug it in. If it doesn't, and you have vacuum on the line, then your vacuum advance unit might be bad, and would cause the gas mileage problem.
thomasiovino
Nov 12, 2014 04:21 PM
fbh31118
67
Jun 19, 2014 01:24 PM
akamacgyver
24
Feb 26, 2013 06:08 AM
Buddy03
15
Jun 4, 2012 08:16 AM
Faithful Old Road Dog
Jan 10, 2004 12:21 AM
