My 99EXP-EB has started to do something funny when I first start the engine in the mornings. As normal all the lights in the dash come on, then when I start the engine the tach and speedometer needle goes to the max (all the way to the opposite side) and the return back to continue to function normally.
I do not know what could cause this behavior on my tach and speedometer, those anyone have experience something like this ?.
I will appreciate any help or suggestions.
Thank you
Roberto.
The gauges will do this each time the PCM is reset. I couldn't imagine why your PCM would be resetting by itself....usually takes disconnecting the battery for a period of time.
Thank you Jim for your reply.
I have a theory that what is doing this is my 3 year old battery. Perhaps at the first start is taking all the juice to start the engine and the PCM reset it self. Just a theory....
FTE Rocks!!! I had the same problem and was about to take advantage of the extended warranty then I read this string and that along with noticing that the Expy was getting a little hard to start. I replaced the Battery and viola! The guages don't jump any more at startup. Whohoo!!!
sweet, Mine does the SAME thing.. sometimes the windshield wipers run once at startup as well, very very confusing, esp if you have a lil bird dookey your trying not to smear on the windshield!!
I will try changing the battery.. Thanks guys.. YOU ROCK!
I have this same problem and I am curious about what harm if any this does to PCM or other systems. Does this mean that the PCM has to relearn my driving habits every time I start the truck. I will be getting a new battery to see if that stops the problem
It didn't seem to harm any systems that I can tell. Whether it re-learns or not is sort of irrelevant, considering after your new battery it will relearn hopefully for the last time.
