Sponsored by: Auxito
FL-820S filter differences
Old Jun 12, 2009 | 07:15 PM
advocate's Avatar
advocate
I bought a couple of oil filters from the dealer so I would be ready for my next 2 oil changes. I didn't look at them until I got home but they are different from each other. The one on the left is what I normally get, the one on the right is smaller and lighter but has all the same numbers on it. Did Ford change manufacturers?
Old Jun 13, 2009 | 12:30 AM
fordmerc's Avatar
fordmerc
I know I have seen "new design, same performance" on the boxes of the new filters at wally world. Havn't heard of any manufacturer change or difference in the filters.
Old Jun 13, 2009 | 12:36 AM
papajoemrt's Avatar
papajoemrt
It's more than likely the same filter that they would like you to use on the FL820S applications. If you read somewhere in the manual or in the parts and service area of the dealer it says that ford keeps on improving their parts to perform better and keep up with updated technology, a change in the design of the oil filter is probably a good thing.
Old Jun 13, 2009 | 04:57 AM
Bobby82490's Avatar
Bobby82490
Look in the Oil section of the forum, we had a thread about the new FL820.
Old Jun 13, 2009 | 05:16 AM
shorebird's Avatar
shorebird
I noticed the difference Monday when I changed the filter on my '08. I put the old filter in the box that the new one came in and it was sticking out. Bobby I looked for the thread and had trouble finding it. Would you please post a link?
Old Jun 13, 2009 | 09:12 AM
galaxie641's Avatar
galaxie641
https://www.ford-trucks.com/forums/8...-fl-820-s.html
No real answers but there it is.
I wish Ford would work more on putting out a 6qt jug of oil instead of shortening filters. I see the geniuses now have a 5.25qt jug, wonderful because none of my 3 modulars take 5.25 qts, nor do they take 5.
Old Jun 13, 2009 | 09:21 AM
whalebird's Avatar
whalebird
I didn't go through the whole thread, but the new one may come out the bottom around the tie rods easier.
Old Jun 13, 2009 | 12:53 PM
galaxie641's Avatar
galaxie641
That is my guess as to why they changed it, on the CV's and the Mustangs it is damn near impossible to remove unless you turn the wheels all the way to one side.
Old Jun 14, 2009 | 01:14 AM
papajoemrt's Avatar
papajoemrt
glad there are other people out there wondering why don't they design a 6 quart jug of oil rather than an oddly dimensioned jug o' oil.
Old Jun 14, 2009 | 06:58 AM
shorebird's Avatar
shorebird
Speaking of the size of oil jugs. I went to buy some Mobile-1 at O'Reilly auto parts and the largest jug that they had was 3.25 qts. for $26. I thought BS and went to wallyworld and got the 5 qt. jug for $22.
Old Jun 14, 2009 | 08:38 AM
dkf's Avatar
dkf
I cut apart an old style FL-820s filter and noticed there was at least a 3/4" of space between the end of the filter cartridge to the center of the dome on the can. I havn't cut apart a a new shorter 820 but I suspect the filter cartridge is the same length they just reduced the can length. They probably shortened it to get more filters out of the same material length, but who knows. The new purolator pure one filters are the short ones also. There is a thread down in the oil and lubrication section.
Old Jun 15, 2009 | 02:31 AM
Bluegrass 7's Avatar
Bluegrass 7
Only thing is on some vehichles there may be a space issue.
They often make a product change to save money and stock fewer different versions to fit wider selection of models.
As far as the filter being just as good' it is, no worry.
Filters changed at 5 to 7,000 miles with the oil means that the filter will never get close to clogging or any filtering problem at those intervals.
If the filter gets anything close to being clogged then there is something in the motor that is wearing way too fast and you would have a problem in a relitivley short time.
Mine is at 118,000 miles with 5k change intervals and still like a new motor using MC 5w20 and the 820s filters.
Old Jun 15, 2009 | 11:34 AM
dkf's Avatar
dkf
If they shortened the filter to accomadate a certain vehicle then they need to change the vehicle not the filter. If the 820 being 5/16" longer interferes with other components then the design is way too close. You have to be able to get a wrench on the filter for removal and to get your hand in to spin the filter on. Of course engineers don't have to work on the vehicle so what do they care.
The filter casing are stamped out on a progressive die. If they shorten the case 5/16" that means they can save roughly 7/16"-5/8" (depending on elongation) of material on the length and width of the piece required for 1 filter. Saving 7/16'-5/8" of steel per filter equates to quite a few more filters per 1000' of sheetmetal. Just a theory of mine.
Ultratravler
6.7L Power Stroke Diesel
54
May 12, 2017 05:12 PM
O43x
Mar 1, 2017 05:05 AM
popatop500
Modular V10 (6.8l)
109
Dec 27, 2016 08:28 PM
djousma
Oct 4, 2016 04:18 PM
hubler13f
Oct 1, 2016 11:50 AM
