4.9L stroker kit?
Old Jun 12, 2009 | 06:25 PM
Bigblack Ford's Avatar
Bigblack Ford
4.9L stroker kit?
does anyone know of anywhere that i could find a stroker kit for my 1993 f150 with the 300 I6?
Old Jun 12, 2009 | 07:04 PM
Franklin2's Avatar
Franklin2
No demand for it since the stroke vs the bore is already pretty long.
Old Jun 12, 2009 | 08:54 PM
Bigblack Ford
what would be the best way to add power to my engine? ive got it tore down and its been bored .030 over ive got flat top pistons and the best cam that comp. makes for this engine. ive also got venom 21lb injectors.
Old Jun 12, 2009 | 09:42 PM
Franklin2's Avatar
Franklin2
Get someone in your area to do some head work. Open up the ports, larger valves, heavier springs to keep control of the heavier valves and higher lift cam that you will be using.
This will raise the horsepower, but also raise the rpm which it is made, so make sure you change the rearend gear to match. Don't try to run a high performance engine like this with a gas mileage 2.75 or 3.08 gear. Pep this engine up and put a 3.73 or higher in there to get that heavy truck moving.
Old Jun 12, 2009 | 10:58 PM
Bigblack Ford
its got 3.73 in it now but its been lifted 6 suspension 3 body and the front leveling kit. im runnin a 38.5X15Xr15 tire too so i was thinkin maybe a 4.56 or 4.88? i kno richmond gear is a popular brand and is what ive been thinkin about investing in. im new to this forum but man i realy like how quick you guys respond. thanks a million
May 10, 2017 07:33 PM
colton04mclean
17
Oct 29, 2012 06:24 PM
TheTowingCowboy
Apr 3, 2011 08:54 PM
fordtruck44
Aug 23, 2008 08:15 AM
fairlaniac
13
Dec 28, 2001 10:04 AM
