Is my tach sensor the culprit?
06-13-2009, 09:18 PM
on
ill have to check my wires tomorrow
06-14-2009, 02:51 PM
I have some brush on electrical tape I'll throw on for now.
06-14-2009, 03:01 PM
Sounds good to me... As long as it's sealed again it should last.
-Enjoy
fh : )_~
06-14-2009, 03:32 PM
Hope that works I'm thinking the same thing is happening internally why else would they always start loosing the insulation right at the sensor instead of anywhere else in the wiring.
06-14-2009, 03:39 PM
That is the stress point on the wires.
All the motor vibes are shaking the bejesus out of them at that point, when the start to heat harden it just breaks away.
-Enjoy
fh : )_~
06-14-2009, 04:18 PM
Yea I have thought of that but if the wires are not touching why would the sensor quit I just always thought maybe getting some internall heat as other wires hooked to the engine are not as prone to cracking near as bad. Hopefully your right it would slow the sale of the new sensors.
06-14-2009, 06:15 PM
It gets moisture in it and fails.
-Enjoy
fh : )_~
06-14-2009, 06:55 PM
Yea that makes sense too.
09-29-2009, 11:42 PM
on
Quote:
Originally Posted by
88f150302
ok i have a question my tach works when i am cranking it bouces but thats it when it starts it dosnt work at all could that be the sensor?
I am having this exact same problem with my Tach, did cleaning it help, or did you end up having to replace the sensor? Thx.
AB
11-08-2009, 03:00 PM
i tested my sensor and got 2600 ohms........does this mean the sensor is good for sure???
11-08-2009, 08:27 PM
on
i also have the same problem, would the bad sensor that bounces the tach all over would that cause the tranny to slip at all?
11-08-2009, 09:07 PM
It i dont think it will make the tranny slip. It will make it shift funny tho.
11-08-2009, 09:43 PM
on
thanks, i will have to check the filter to see if it fell off..
02-14-2010, 02:04 PM
I finally replaced my tach sensor and it works perfectly now. Now I know what my cold idle speed is. It doesn't bounce with the turn signals anymore either. I love having a fully functioning guage cluster.
Aune163rd
12-13-2014 08:02 AM
Macs1964F100
13
07-11-2014 11:21 AM
03trueblue
08-26-2012 09:30 AM
scottscott
04-22-2010 04:08 PM
hugger94
11-29-2008 08:03 PM
1991 ,
1993 ,
460 ,
69 ,
73 ,
86 ,
buy ,
diesel ,
f350 ,
ford ,
sending ,
sensor ,
tach ,
tachometer ,
wiring
