Oil pressure issue
Old Jun 11, 2009 | 07:43 PM
tjwc1's Avatar
tjwc1
Unhappy Oil pressure issue
Hello I have a 93 351w in a f350, When the engine is cold it runs on the higher side of the normal mark, under idle and under high rpm and driving.
But when it warms up it stays at the same place under driving and just above idle but, but at idle (stop light) if starts bouncing down towards the zero mark and will go all the way down there, i just keep a little throttle on and it come right back up. I will be installing Mechanical gauge very soon. ANY Ideas on what this might be? what pressures should I see on the mech gauge for this engine?
Thanks in advance
TJ
Old Jun 11, 2009 | 10:22 PM
subford's Avatar
subford
dup disregard
subford's Avatar
subford
The dash gauge will read zero until the pressure reaches 5 PSI and then it will read normal in the center of the scale. That is the only two positions it has. It works like an oil light.
Oil Pressure Hot @ 2000 RPM PSI 40-65.
WorkhorseF250
Modular V8 (4.6L, 5.4L)
Apr 21, 2013 08:09 PM
oldmanbergie
Dec 9, 2010 12:06 PM
RobLenski
2009 - 2014 F150
Mar 10, 2009 07:39 AM
tmryan362
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Apr 16, 2004 01:59 PM
schapman
Nov 20, 2003 12:48 AM
