Cracked Rotors?!
Old Jun 16, 2009 | 04:49 AM
Copedawg's Avatar
Copedawg
Originally Posted by Neal 97 250
To answer your question on how long you can drive like this, I would say none. I would not drive on broken rotors at all.
To replace the rotors you will need to remove the hub. You will need the hub nut removal socket. You can get it at most parts stores. Not all will have the right one though so be careful. Once the hub is off you will have to drive the lug studs out. This takes a big hammer and a little sweat. Once out the rotor will fall off. Replace the rotor and drive the lug studs back in. replace the hub and brakes and you are done. If you have a repair manual that helps with torque specs etc.
I am still trying to get all my ducks in a row, once I start I won't be able to run to the store. What is the correct size of this hub nut removal socket?
Old Jun 16, 2009 | 06:22 AM
BlueMule's Avatar
BlueMule
Manual or auto hubs? Manuals take a 4 prong 2.5" socket. I never could find the correct one for the auto hubs so I removed them with a screwdriver and then put in a set of manual hubs.
Old Jun 16, 2009 | 06:31 AM
BlueMule's Avatar
BlueMule
There are two different styles of spindle nut sockets for the manual hubs.
and here'sthe 3 piece locknut set they are used for
Old Jun 16, 2009 | 06:50 AM
Copedawg's Avatar
Copedawg
I have the manual Warn? hubs. I cannot see your pics (Uncle Sam won't let me see them). If it is 1 of 2, perhaps I will buy them both and return the one I don't need.
Old Jun 16, 2009 | 07:06 AM
BlueMule's Avatar
BlueMule
The pictures were of two different types of sockets from different manufacturers
The part number for the one that NAPA sells is SER3246
And the PowerBuilt part number is 648477
I originally bought the NAPA piece but later found the powerbuilt at Checker for about 1/2 the price so I returned the one to NAPA
Old Jun 16, 2009 | 09:05 AM
Copedawg's Avatar
Copedawg
Thanks, I think I have enough ammo to shoot myself, lol. I will let you know how it went.
Thanks again!
reamer
Nov 30, 2016 06:44 PM
1953FlatJohn
23
Nov 10, 2016 05:51 PM
maxum96
Oct 28, 2016 08:15 PM
deputydog03
Modular V8 (4.6L, 5.4L)
32
Apr 9, 2016 12:06 AM
gatesj
Feb 27, 2006 03:44 PM
