need ignition help (coil problem)
Old Jun 11, 2009 | 04:06 PM
Black79's Avatar
Black79
79 f-100. 302. new coil and distributor. Coil is grounded and has 12 volts going to it but i'm not getting fire to the distributor.
Old Jun 11, 2009 | 04:15 PM
bigun72's Avatar
bigun72
check the brain on the fender well...... i dont kno the correct name for it im shure somebody does.....
Old Jun 11, 2009 | 04:43 PM
Black79's Avatar
Black79
i tried 3 of them. one of them is new. still nothing.
Old Jun 11, 2009 | 04:46 PM
bigun72's Avatar
bigun72
its gotta be sumpthin small..... did u put a new button in the dist?
Old Jun 11, 2009 | 04:49 PM
Black79's Avatar
Black79
yea, new cap and button. new plugs and wires. Im just not getting fire to the dist.
Old Jun 11, 2009 | 04:52 PM
bigun72's Avatar
bigun72
man i dont know.... i bet you a fustrated , i just recently had to put a new distributor in my 77 , its a pain when you fix somethin and it still dont work....
Old Jun 11, 2009 | 04:54 PM
Black79's Avatar
Black79
i'm pullin my hair out here. I just put a motor in the truck and i've been at this tiny problem for 3 days. I still aint heard my motor run.
Old Jun 11, 2009 | 04:57 PM
bigun72's Avatar
bigun72
EXACTLY wat happend to me , just rebuilt my 400..... it took me 2 days to figure out my problem..... but once she cranked i was jumpn up and down lol
Old Jun 11, 2009 | 06:40 PM
fmc400's Avatar
fmc400
MSEE
Originally Posted by Black79
Coil is grounded
You don't ground the coil! The negative end (TACH) side of the coil is switched. A coil can't fire unless it's switched on and off. On a '79, the coil negative terminal is switched by the Duraspark module.
AND... you don't run 12 volts to the coil at all times. In RUN it is powered through a resistive wire that effectively drops the coil voltage to 7-9 volts. In START this resistive wire is bypassed by full voltage, but during cranking it usually drops to about 9 anyway.
Is your wiring hacked up or something? What's the deal here? Tell me what you've done (or haven't done) and I can step you through wiring your ignition.
Old Jun 12, 2009 | 05:58 AM
Black79's Avatar
Black79
All the wiring is factory and in great shape. I guess I made my post a little confusing. I was talking about the coil mount being grounded if that mattered.
Regardless, the problem is fixed. I discovered there was a screw missing out of the module in that NEW distributor which was causing it to not get a ground.
Old Jun 12, 2009 | 08:27 AM
fmc400's Avatar
fmc400
MSEE
Ah, that will definitely do it. Glad to hear you got it worked out!
