it was the connection to the BPA switch. thanks alot, i now have cruise. All i have to do is get the reverse lights on, and everything in the truck will be in working order.
Matt if your girl is big enough to require a crew cab to fit in and a dually to haul her with out bottoming out, Im never inviting both of you to a BBQ, i couldnt afford it.
Wasn't the fire related recall due to a combination of High current through that switch while off plus brake fluid leaking into the switch? I have a question about CC why would it shut off if you hit a nasty pot hole at highway speed?
