fuel pump replacement
Old Jun 11, 2009 | 10:40 AM
corpuspits's Avatar
corpuspits
Ok sorry searched already and cant find any pics. bought a pump from orielly and put the tube on the suction side of the pump. There is a oring and 2 washers that I can use .I used the oring only and it sucking air on suction side of pump.Washers look like crush washers but dont look like it will seal with the o ring. excursion 7.3 anyone deal with this
Old Jun 11, 2009 | 11:20 AM
corpuspits's Avatar
corpuspits
ok think I got it but wont pick up do i need to prime the pump still not picking up .
Old Jun 11, 2009 | 11:49 AM
corpuspits's Avatar
corpuspits
bad pump put old one on and it picks up.......
Old Jun 11, 2009 | 02:29 PM
wla6518's Avatar
wla6518
are you ever up in San Antonio?
I have a slightly used pump you can have if you need a new one.
I replaced the pump thinking it was the problem with my fuel system, it turned out to be a clogged pre-pump filter.
Pump was only a year old.
wla6518's Avatar
wla6518
sorry for the double post
Old Jun 12, 2009 | 05:09 PM
corpuspits's Avatar
corpuspits
no but thanks alot
