Speedometer gear question
Old Jun 10, 2009 | 09:13 PM
ramtrk's Avatar
ramtrk
I have just been given a 1978 F150 Custom that belonged to my Grandfather, then my Father. It has a 302, with the 4 speed manual floor shift(3 with o/d), 3.00 gears in rear end, and will be putting 225/75/15 inch tires. The speedometer gear is not present at all. Does anyone have any idea what gear to put in this truck? It is definitely all stock.
Mike
Old Jun 11, 2009 | 09:15 AM
4x4 Bart's Avatar
4x4 Bart
Ford Motorsports Uses This Formula:
Driven Gear Teeth = (Drive Gear Teeth x Axle Ratio x Tire Rev. Per Mile) / 10
225/75/15 = 735.5 tire revolutions per mile.
You need to count the number of teeth on the drive gear (in the transmission).
These are hard to count. Clean the oil off a tooth and mark it with a sharpie, then count.
Old Jun 11, 2009 | 09:18 AM
sgsavvy's Avatar
sgsavvy
i din know that formula, thanks!
