Sponsored by: Real Truck
HELP!!! Left side tail lights not working
Old Jun 10, 2009 | 12:13 PM
MikeHall's Avatar
MikeHall
Checked fuses and replaced bulbs but the left side tail lights are still not working. The front turn lighs and mirror lights work but the running/brake or turn signals are working on the left side. Could someone give me an idea of where to look for this problem?
thanks
Mike
Old Jun 10, 2009 | 12:16 PM
bpounds's Avatar
bpounds
So, on the left rear light assembly, nothing works? How about the backup light? Sort of sounds like a ground issue on that one fixture. Has there been any work done back there around the bumper or fixture?
Old Jun 10, 2009 | 12:19 PM
MikeHall's Avatar
MikeHall
I didnt think to see if the back up lights work. There has been no work done back on that side of the truck nor anywhere on the back. Where would that side of the lights be grounded? It wouldnt hurt to check that out.
Thanks
Mike
Old Jun 10, 2009 | 12:27 PM
MikeHall's Avatar
MikeHall
Backup lights work. None of the wiring has ever been messed with nore do i see any kind of damage to the wiring. the truck is a 05 F250 4x4.
Mike
Old Jun 10, 2009 | 03:12 PM
bpounds's Avatar
bpounds
I guess my next step would be to pull the connector off of the fixture, and check to see if you are getting voltage at the connector. I'm looking at the schematic, and I don't see anything that would break both parking and brake lights, and nothing that would break parking on one side but not the other.
If you don't have voltage at the connector, with a VOM from the pins to ground, then you will have to trace that wiring loom forward. You might have a body connector that has come disconnected. The front parking lamps, the clearance lamps if you have them, the mirror clearance lamps, are all one circuit with common fuse, so it almost has to be a wiring problem or a lamp fixture problem.
Albertcole
May 12, 2014 10:12 AM
37 Ford guy
16
Sep 15, 2013 04:50 PM
hp246
Jun 21, 2009 02:06 PM
jsand
Jan 24, 2006 06:20 AM
hillbillydad
Apr 5, 2004 12:29 AM
