No brake lights, turn signals or flashers??
Old 09-09-2014, 11:59 PM
TSmylie's Avatar
TSmylie
TSmylie is offline
So about 6 months ago, I had this same problem, I read it's most commonly due to a short in the brake control switch on the brake pedal. So I swapped the brake control switch, replaced the fuse, and all was good.
Now, I'm having the same symptoms, so I switched the brake control switch with another new one, popped in a new fuse, ... And the fuse blew again. I disconnected the wiring harness to the brake control switch, and it still blew another fuse.
I read the flasher relay shares the same circuit, swapped the relay, ..and it still blew another fuse!
What else is on this circuit that could be blowing fuses???
Thanks in advance for any info
Old 09-10-2014, 06:05 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
Which year and engine?
What fuse #?
WHEN does the fuse blow (immediately upon insertion, when brake pedal is pressed, ignition switch position, etc)?
Old 09-10-2014, 09:40 AM
TSmylie's Avatar
TSmylie
TSmylie is offline
2000 excursion v10. Fuse #13 blows immediately when you insert it. No foot on brake pedal
Old 09-10-2014, 06:36 PM
projectSHO89
Did you ever have recall 05S28 performed? If not, go out immediately and unplug the connector on the brake master cylinder. Don't ask why, JUST DO IT NOW!
Old 09-10-2014, 10:09 PM
TSmylie's Avatar
TSmylie
TSmylie is offline
I imagined you saying that in Arnold Schwartzenegger's voice. Ok I unplugged it, I have no idea about the recall I'll call ford tomorrow with my vin and check about the recall
Old 09-10-2014, 10:11 PM
TSmylie's Avatar
TSmylie
TSmylie is offline
So will the truck be ok to drive with it unplugged?
Old 09-11-2014, 06:43 AM
projectSHO89
You won't have cruise control with that switch unplugged. Also, if the recall was never performed, the truck won't randomly self-combust, which, unless you want an insurance payout, is assumed to be a good thing.
Did that disconnection resolve the fuse blowing or not? That switch is, by far, the most common cause but is not the only possibility.
With the fuse blown, the risk of fire is nil, but there's always the temptation to put in a larger fuse which might not blow in a misguided attempt to restore brake lights. Better safe...
Old 09-11-2014, 09:39 AM
TSmylie's Avatar
TSmylie
TSmylie is offline
I haven't put a new fuse in yet as I ran out. I'm going to go get new guess this morn and check
Old 09-11-2014, 07:21 PM
TSmylie's Avatar
TSmylie
TSmylie is offline
Update! With the cruise control deactivator switch unplugged, it does not blow the fuse any more!! Thanks projectsho for the info. I called the dealership and they say the recall already has been done. And I would be liable for the repair. We'll I don't use cruise control anyway so it's just going to stay unplugged.
Old 09-11-2014, 09:28 PM
projectSHO89
Part is about $20-25 at the Ford part counter and takes all of 5 minutes to replace.
Old 09-13-2014, 12:13 AM
TSmylie's Avatar
TSmylie
TSmylie is offline
Another update, just my curiosity I unplugged the wire harness from the cruise control brain on the passenger side inner fender, under the hood, and my harness is melted!! So it may not be the deactivator switch on the master rather than the control modual itself. !!
Old 09-14-2014, 03:45 PM
projectSHO89
What was the color of the wire(s) on the connector where it was melted?
Cleevey
Large Truck
10-15-2016 09:08 PM
clunker86
Electrical Systems/Wiring
04-07-2007 12:47 PM
carrfamilynj
03-03-2007 11:26 AM
robertp
1997-2006 Expedition & Navigator
06-14-2004 09:36 PM
mgrimm01
04-13-2004 08:16 AM
Quick Reply: No brake lights, turn signals or flashers??
