Ignition question
Old Jun 10, 2009 | 12:06 AM
F-250 restorer's Avatar
F-250 restorer
Ignition question
Hey guys--
I have a '75 F-350. I'm putting a '78 300 in it (and not using the Ford box) . With a DS2 dizzy and TFI coil wired directly to an MSD 6a box, do I need anything else...resistor, module, etc.?
Old Jun 11, 2009 | 08:20 AM
kernel-panic's Avatar
kernel-panic
Not sure if the 6a box would replace a module or not. The affordable homebrew hybrid ignition I've seen a lot of info on is a DSII distributor with the 4-pin GM HEI ignition module with the TFI coil - no ballast resistor required.
Old Jun 11, 2009 | 12:28 PM
Harte3's Avatar
Harte3
Don't think you need anything else. Check the MSD site for the wiring diagram with a DS2.
jimmyboy111
Apr 5, 2017 09:28 PM
BII Plow Truck
Feb 17, 2017 01:52 PM
Sleepyguy
Sep 29, 2016 11:14 PM
FuzzFace2
Feb 26, 2016 03:19 PM
Smiline
Feb 16, 2016 10:15 AM
