TBC failure
Old Jun 9, 2009 | 07:15 PM
fordpower1973's Avatar
fordpower1973
TBC failure
I was hoping someone might be able to help me. My brakes completly went out when I tried to stop and a "TBC fault" indicated. I was able to get the truck stopped but as soon as I let off the brake pedal the fault goes away but still no brakes. I have no fluid leaks and the fluid level is good. I have no idea what TBC fault is. Any help mwould be appreciated.
Old Jun 9, 2009 | 07:22 PM
liv's Avatar
liv
The TBC is your Trailer Brake Controller. No way related to your trucks brakes. If you have no fluid leaks I'm guessing your master cylinder is shot.
Old Jun 9, 2009 | 07:30 PM
fordpower1973
Thanks for the reply. The master cylinder and both front calipers were replaced about 2 months ago. I know that anything can go out at any time, is there any fuses that might control this?
Old Jun 9, 2009 | 07:33 PM
liv's Avatar
liv
You can pull the Fuse for the trailer brake controller. Look in your owners manual for that.
Maybe a collapsed brake line? Your problem is definitely not electrical it's mechanical. Nothing electric can cause the brakes to completely fail.
I found this if its some help on getting rid of the TBC Fault.
TBC Fault - Diesel Forum - The Diesel Stop.com
Old Jun 9, 2009 | 07:44 PM
fordpower1973
Thank you. I am glad I found this site. And again thank you for the quick response. I am going to trouble shoot the brakes and worry about the fault after I get it home. Thank you.
Old Jun 9, 2009 | 07:55 PM
liv's Avatar
liv
No problem. Good luck and don't hesitate to ask anything else.
