Sponsored by: Real Truck
steering wheel noise
Old Jun 9, 2009 | 04:09 PM
dmch2oski's Avatar
dmch2oski
question about steering wheel noise. When I turn steering wheel in either direction on f250 I get a squeaking noise from the steering wheel. What did you think is up?
Old Jun 9, 2009 | 06:50 PM
busdriver47's Avatar
busdriver47
my f350 does the same thing. also my wife has a p.t.cruiser that does the same thing.wish i knew what the fix is.
Old Jun 9, 2009 | 06:58 PM
Furian's Avatar
Furian
You Keep What You Kill
Check out this thread:
https://www.ford-trucks.com/forums/8...-steering.html
Old Jun 11, 2009 | 12:39 PM
dmch2oski's Avatar
dmch2oski
thank you for the thread. however the noise really seems to be coming from right under the steering wheel and not traveling from below up the column.st
Old Jun 11, 2009 | 12:52 PM
senix's Avatar
senix
I had the same noise in my 06. Thought it was a dry bearing or something. Played with it for a couple of weeks, replaced the entire column at one point.
It was the steering box. One that was changed all was quite. So I think I would start there and look at that box.
