Timing Cover problems.
Old Jun 9, 2009 | 03:19 AM
ccg711's Avatar
ccg711
Ok, so for those not following the epic money pit story of my truck here's the backstory. Truck was dusted in previous life, and after I got it, it failed catastrophically by ingesting it's own compression rings on #5&7 cylinders. Now for my new problem. During re-assembly of my newly purchased long block, I noticed a gouge in my timing cover at the mounting surface for the main oil pump. Specifically the gouge is between the oil intake side and the oil output side of the cover. Like the original oil pump picked up the ring bits from the failure and then dug a trench in my cover. This obviously has a problem for flow and pressure. So here comes the dilemma. Local machine shop said they could dig it out, and heliarc/tig weld the aluminum back to fill it in, then machine it down flat. The IH house wants $393 for a replacement. The dilemma comes from what I'll loose by having it fixied. That would be several thousandth's off the mating surface and the forward face surface that mates to the oil pan. So does anyone know of any problem with having this kind of work done? The shop quoted $130 to fix.
Chad
Old Jun 9, 2009 | 06:26 AM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
That shouldn't be an issue. How deep is it? I have a front cover at the machine shop right now, they are removing a few thousands from the oil pump mating surface because mine has some scratches in it as well.
Old Jun 9, 2009 | 07:34 AM
Kwikkordead's Avatar
Kwikkordead
I don't see a problem with that either.
mmm635
6.7L Power Stroke Diesel
24
Dec 24, 2020 06:41 AM
LordKamakazi
Oct 9, 2016 11:26 PM
lkforney11
May 9, 2016 12:40 PM
Benchwarmers6
24
Mar 18, 2016 12:34 PM
chrison600
Feb 6, 2014 08:54 PM
