Sponsored by: Real Truck
Truck Shopping
Old Jun 8, 2009 | 08:38 PM
gitane59's Avatar
gitane59
Truck Shopping
Ok I might have found a new truck for my wife. Her truck (the one in my signature) is getting older and I just found a 2006 F350 V10 dually 4X4 Crew CAb Lariat loaded with moonroof with less than 40K miles . Strange part is, it's a short box!!! How many of these did they build? Sure would be better for my wife to manuouver than a LWB dually. Anything I need to look out for specifically??
What was the GVWR that year for that truck and what was the stock rear-end ratio??
We have never owned a 4X4 before. Do I reading remember something about a front end speed wobble only with the 4X4's?? Our current v10 has been excellent and wifey does not wanted a diesel so that's not a problem.
Thanks guy's
Old Jun 8, 2009 | 09:33 PM
Wash1331's Avatar
Wash1331
Sounds like a great truck if the price is right. I own a '06 4wd with no problems in the front end, just don't try to run on dry ground with it engaged at speeds above 45. Make sure you get an oasis report. Good luck.
Old Jun 8, 2009 | 10:54 PM
jake00's Avatar
jake00
rear should be a 4.1 or 4.3
the short bed is more common than the long
I bought my 06 a year ago with 39k on it for 20 grand.
Old Jun 9, 2009 | 01:09 AM
BMWM1's Avatar
BMWM1
Ball joints seem to wear out pretty quick but not that big of a deal if its a truck you really like
Old Jun 9, 2009 | 02:43 PM
snelldawg's Avatar
snelldawg
Make sure that you don't get any vibrations/shaking/hopping at various speeds. The driveline vibrations in these trucks can be annoying and practically impossible to fix, even if under warranty.
Old Jun 9, 2009 | 05:04 PM
Ballswedge's Avatar
Ballswedge
A short bed dually is more common than a long bad dually? I dont think so. I've never seen one.
Old Jun 9, 2009 | 05:05 PM
Ballswedge's Avatar
Ballswedge
My last set went 150k...
Old Jun 9, 2009 | 05:39 PM
BMWM1's Avatar
BMWM1
Where they stock or after market?
Old Jun 9, 2009 | 05:43 PM
Ballswedge's Avatar
Ballswedge
Stock. My new ones are Napa.
Old Jun 9, 2009 | 07:07 PM
Furian's Avatar
Furian
You Keep What You Kill
I have to agree... a short bed dually is pretty rare and potentially highly desired with a CC configuration.
