When running the A/C we are getting drip drops on the passengers toes. I can't remember what that thing is that I need to do to unplug whatever is plugged up. I tried to do a search using varius terms with A/C, leaking, dripping etc. and did not find a correct write up.
Can someone tell me what/how I need to fix this problem or point me in the right place to find one that has already been posted.
This happened in my cavalier a few years ago, since it was under warranty i took it in
and all they did was blow out the little rubber hose that drains the condensation out of the evaporator box.
Hopefully someone here will know where the drain is on these trucks.
I agree with Patrick and Jim, look uder the truck for condinsation dripping under inside the passenger side tire area, if none there, its prolly clogged..
Yeah...it is dripping but nothing near like it did last summer.....used to would make a small pond under their from the A/C.
How do I find that drain plug thing to fix the pluggage..........
sounds like the drain tube in clogged. you can't see it on an e-series (you need someone with small hands to get to it). i don't know about the f-series.
Bumpity-bump...cause my air works good,but it dont drip condensation outside.Im also wondering where to check/clean out.Sorry for the higfh jack...Phil
