I have a 97 F150 4x4 Lariat. When I first start it the gauges read normally. Then after a while the gauges go nuts. The battery gauge maxes out, the oil pressure goes low, the temp maxes and the fuel gauge will either max or go to empty. If I shut the truck off and restart the gauges will read normally again for a few seconds/minutes. Any ideas?
A number of different things could be causing that, one of them is the battery itself. I would have it checked to make sure it's not shorting out. You can also get more info about your truck here: 1997 - 2003 F150 - Ford Truck Enthusiasts Forums Try that board out and see what others recommend. Did you know we have a board for your state? You can use it to find out what others near you are doing or get tips on where to go for reliable help: Missouri Chapter - Ford Truck Enthusiasts Forums
Welcome to the board.I wonder if the battery is spiking,is it an old battery? They can test it at Autozone for you,however I did have a 5 yr old battery test good and it was bad.
I changed the battery just to see. It didn't help. I found out that all of the gauge cluster is grounded by one wire. I think I will check that ground wire, and see if that helps. Any other ideas?
