Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Alternative heat
Old Jun 8, 2009 | 01:38 PM
murph77's Avatar
murph77
Alternative heat
A friend of mine is getting tired of expensive heat bills in his little work shed.
He is looking into using a windmill powered alternator and a converter to use electric heat.
Apparently, a GM alternator works better because they have an internal regulator.
Any one ever done this, or heard of it being done?
Old Jun 8, 2009 | 03:52 PM
frederic's Avatar
frederic
Easier than building a windmill and doing electrics would be to install a used wood or pellet stove. Put a coffee pot on top and any tinkerer will be a happy tinkerer!
Old Jun 8, 2009 | 11:46 PM
Ford_Six's Avatar
Ford_Six
An alternator doesn't produce useable power until 1500rpm, that's a bit fast for a windmill. I've got a design penned up a a parts hunt going on now for a very low loss step-up gearset to power a car alternator from a 150rpm 15' windmill.
Another option is a waste oil burner, you can either make your own or get an Army ten heater and run it off diesel, WVO, or whatever else you can make burn.
Old Jun 10, 2009 | 05:48 AM
rsylvstr's Avatar
rsylvstr
get the oil burner...i can ship him my used oil for a good price
Old Jun 10, 2009 | 05:07 PM
*2fords*'s Avatar
*2fords*
Wouldn't a generater out of an old truck work? you know before there were altinators lol.
Anyways I used to have a double barrel wood stove in my shop that worked great, heated it real quick. I bought the parts someplace I can't remember for about 35.00 and got 2 55 gallon drums from work.And the stove pipe at Lowes.
Old Jun 10, 2009 | 06:06 PM
PupnDuck's Avatar
PupnDuck
Not a very efficient or practical way to heat a shop. IF you get a high output alternator (say 100 amp) and IF you could spin it continuously at say 2,000 rpm you would get about 1,200 watts out of it. That's less than what you get from one of the 1,500 watt cheapo heaters from Home Depot. Almost anything else is cheaper and more efficient.
Old Jun 10, 2009 | 06:25 PM
yellowrosefarm's Avatar
yellowrosefarm
Now, if he built an active solar panel, (read black wall or roof covered with piping and sealed with glass on top) and used the windmill/alternator to charge a 12v battery that is used to run a pump to move water through the solar panel and into some old fashioned radiators in the shop, he might have something.
Old Jun 10, 2009 | 06:36 PM
Ford_Six's Avatar
Ford_Six
Nope, you'd be worse off. Those generally make 35a maximum, and the power output is a continuous slope rather than a quick rise to a flat peak like an alternator. They really don't make maximum power until they are at around 3500-4000rpm.
Old Jun 10, 2009 | 10:19 PM
Chaosracing's Avatar
Chaosracing
I have seen those kind of windmill/alt combo kits on TV already (Planet Green I believe) They do use a GM alt (although a Ford 3G alt will also work). The system is geared so the alt spins st the correct RPM, but its only usefull for making a small amount of electricity, not for heat. Like suggested before, I would look into a cheap wood stove, pellet stove or a used oil furnace. If he goes with a used oil furnace though, he will need someway to keep the oil at a decent temp for flow.
Old Jun 11, 2009 | 07:31 PM
Ford_Six's Avatar
Ford_Six
He needs this:
Oil-fired Tent Heaters
The fuel tank is indoors, within 5-8ft, and a little above the burner height.
You can get similar results with this:
Oil Burner Unit for M-1941 Tent Stove [294101] - $49.95 :: Colemans Military Surplus LLC - Your one-stop surplus store with Army/Navy products for hunting gear, camping gear, emergency products, and survival products
Just mount it inside a woodstove, pot-bellied stove, or the tent heater it's designed for. I have one, well worth it.
Old Jun 13, 2009 | 03:03 PM
Homemade's Avatar
Homemade
I used to work in an old quanset hut rebuilding torque converters when we cut them open we saved the oil and dumped it in a 500 gallon tank out back and in the winter that tank fed the heaters in the ceiling all winter.
Was a pretty good setup.
