a.c. is blowing hot
Old Jun 8, 2009 | 12:42 PM
lillbro11's Avatar
lillbro11
a.c. is blowing hot
I just changed the heater core yesterday and today it was blowing hot even with the a.c. on cold. I changed it because it was leaking. Before I changed it I had vise grips on the two hoses to stop the leak in the cab. I'm not sure how the whole a.c. system works as far as dampers and all of the vacuum lines opening them. any help will be much appreciated thanks
Old Jun 8, 2009 | 04:06 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
I don't know about this, but it will get you back to the top. Bump.
Old Jun 8, 2009 | 04:42 PM
nlemerise's Avatar
nlemerise
Did the AC work when you had the vise grips on the water lines? Is the clutch engaging on the AC compressor?
Old Jun 8, 2009 | 04:49 PM
lillbro11's Avatar
lillbro11
yes but it would get a little warm every once in a while
Old Jun 8, 2009 | 09:39 PM
nutfarmii's Avatar
nutfarmii
Have you taken the teflon spacer washer off the compressor yet? This should help your AC it did mine, of course verify the heater core hoses are in correct to.
I will post a photo tomorrow of the bolt that you back out and remove a"shim" washer and put the bolt back in. Others may chime in soon.
Old Jun 8, 2009 | 10:36 PM
SpringerPop's Avatar
SpringerPop
You mean this?
https://www.ford-trucks.com/forums/5...ml#post4464164
So far, the original poster hasn't given any reason to suspect this, but it couldn't hurt to check, either.
Pop
Old Jun 8, 2009 | 10:42 PM
nutfarmii's Avatar
nutfarmii
yes SpringerPop that would be the one, I added this because mine exhibited similar and i removed the shim as per your post and it worked.
It cant hurt....you get more rep for this
later
Old Jun 9, 2009 | 11:55 AM
lillbro11's Avatar
lillbro11
thanks for the replies i'll try that as soon as I get a chance and if anyone else has ideas please let me know
